Hello all.
This is my first post. I did try searching for the issue but I miss the keywords.
I have a problem with Edit Poly modifier applied to a Plane.
The material don't get applied right if the polygon is not equally triangulated.
I have attached a screenshot.
Thanks in advance.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
As rendermaster showed in his edit of your screen shot, checking the box for Preserve UVs does work to keep your material mapping in most cases. However, I suggest adding a UVW Map modifier after you've edited your object to ensure there is no unwanted stretching of the mapping.
Chris Medeck
