Upload ur .max file lets have a look because i'm lost like that ! and show where u want new in other better pictures... or put any small object in that area call it new polygon location
Select the edge between the two polygons, and from the Edit Edges rollout
Click the small settings button near Extrude, and from the Extrude Edges dialog set the
Extrusion height to 0, and set the Extrusion Base Width to the amount that you want.
HI Mate.. Just delete the verical line then select the middle edge and select chamfer from Modify> Edit Edges> Chamfer. Now Alt+C for cut tool to make verical cut as shown in image 3.
Hope this will help.
Thanks and Regards,
Irshad Shah
