hi..please how can I fix this issue??
Solved by Alfred.DeFlaminis. Go to Solution.
You have not given much info to work with but I will make the following suggestions:
1) sometimes the installer itself will be corrupt - If possible download another installer -
2) do not run 3dsmax while installing.
3) be sure vray points to your 3dsmax install directory
4) sometimes I find running the installer as admin helps, especially with win9/win10 - just r-click and say run as admin.
5) if you have more problems - check out the vray site forums
6) be sure you completely uninstall previous vray installations -
let me know if any of these work
Hello @Anonymous and @vtkong.com and welcome to the community,
Autodesk does not make Vray, this question should be directed to the good folks at Chaosgroup. Also, your version of Vray is way out of date so you might want to grab the latest version from the Chaosgroup website.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
This is fix error, tick " remove vray.." please view image
I have a vray installation problem both revit and 3ds max 2014
@Anonymous wrote:hi..please how can I fix this issue??
