Solved by Elizabeth.Leung. Go to Solution.
Hi, the source of your problem is probably related to your graphics cards and/or graphic drivers.
First,assuming your graphic card is fully compatible with 3ds Max, make sure the drivers are up to date.
And next thing you can do, go to 3ds Max, preferences settings, viewport tab, and change the display drivers, restart 3ds Max.
Could be something else, but this is where i would start troubleshooting.
Hello @Elizabeth.Leung and welcome to the community!
When these objects fade away, are they turning into boxes or disappearing entirely? I wonder if this is a viewport clipping issue or an adaptive degradation issue. Would it be possible to get a screenshot of your issue please?
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
This issue seem to be related to 'Improve Quality Progressively'
Go to viewport configuration->Display Performance and uncheck this option.
See if this fixes your problem.
Hello @Elizabeth.Leung,
I just wanted to follow up here, any progress on your issue?
Best Regards,
Thanks for the help! So I tried some things out and it didn't work but I double checked if my 3D max was up to date and after the update, the issue seem to have went away! :]
Thanks again!
Thanks for the update, I appreciate it. Glad it's working for you now!
Best Regards,
