Hi, please help.
Hardware acceleration(GPU) on MAssFX toolbar dont work !
spec
Win 10 x64
3dsmax 2016 sp4
GPU - GTX 960 4gb
I open Nvidia sample scene press simulate, and its simulate on CPU NOT GPU ! (Hardware acceleration i turned ON)
I update Latest GPU drivers, update PhysX Toolbar (3.4) and try again - nothing ! Again simulate on CPU !
I go in office and try on different machines with diferent GPU and max 2014 2016 2017 - NO GPU acceleration all my pc simulate on CPU only !
please help(
Look at my screenshot
but - iray or lucid physics use my GPU by 100%
p.s. found some people replace PhysX3Cooking_x64.dll and its work fine ... but all link are dead (
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Coldworld and welcome to the community,
I've looked into this for you. This issue has been logged into the bug tracker previously. The problem is that the updated SDK for MassFX was never completed so the functionality doesn't currently work.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
