3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Error Code 193 with 3ds Max 2014
2 REPLIES 2
5607 Views, 2 Replies
I recently upgraded from Max 2013 to 2014. I moved my plugins over, specifically the Blur Studios Fire plugin. Now when I start Max I get "Error Loading Plugin DLL, Error Code 193 - %1 is not a valid Win32 application"
I'm using 3ds Max 2014 64bit in Windows 7, and had previously been using 2013 64bit. Any ideas as to why these plugins are suddenly not working?
2 REPLIES 2
Steve_Curley
You can't "move" plugins between versions, you must upgrade those plugins to the match the version of Max - different versions of Max, and the plugins, are created with different versions of the compilers and are therefore not compatible.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
I have the same problem in 3ds max 2015.
from one day to the other, this error appears. Security has more to do with windows that 3ds max but I can not solve.
probe uninstall it and install the 3ds max again but the error persists.
DLL <c:\3ds Max 2015\stdplugs\Body_Object.dlo> failed to initialize.
Error code 193 - %1 no es una aplicacion Win32 válido.
DLL <c:\3ds Max 2015\stdplugs\ATFExport.dlo> failed to initialize.
DLL <c:\3ds Max 2015\stdplugs\Proboolean.dlo> failed to initialize.
Tags (1)
