Hi, i have the operating system Windows XP 32bit.
I use 3DS MAX 2013 and mental ray.
I can't do rendering, even in resolution 1000 - 750, because it came out that my memory is full and appears the ERROR BITMAP, even if I crop the scene in more parts.
Why?
What can I do?
Where I have to go to unable the BITMAP PAGER in 3ds max 2013?
I go in Customize - Preferences.. - Rendering..but I can't find BITMAP PAGER.
Thank you
Erika
I think this is what you might be looking for, see screengrab below.
You need to check 'Page Large Images to Disk'.
Enabling the Proxy System will increase your viewport responsiveness by lowering the resolution for any shaded/realistic viewport bitmap textures.
You shouldn't have to do any of this though, your pc must be quite underpowered?
Is it a laptop with minimum ram and onboard integrated graphics?
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Prova a cliccare qui, vedere la schermata di afferrare sotto.
Se questo non funziona provare ad andare al menu Start di Windows;
Tutti i programmi -> Autodesk -> 3dsmax -> selezionare una modalità scheda grafica differente (se disponibile).
Poi il pulsante che dice "OK, generare proxy ora".
La tua foto sembra una versione piuttosto vecchia di 3dsmax, che versione è?
Il vostro computer portatile potrebbe non essere abbastanza potente.
Ricerca Google per le «specifiche minime di sistema 'per la versione 3dsmax.
Darawork
AutoDesk User
1) I have the 2013 version of 3ds.
these are the charecteristics of my laptop (Samsung R70):
Processor: Intel Core 2 Duo T7100 1.8 GHz
Mainboard: Intel PM965
Storage: 2048 MB, DDR2 PC5300 SDRAM, max. 4096MB, 2x1024MB
Graphics: NVIDIA GeForce 8600M GS - 256 MB (see attachment!)
Screen: 15.4 pollici 16:10, 1280x800 pixel, WXGA Glare Type TFT Display, lucido: si
Harddisk: 160 GB - 5400 rpm, 160 GB 5400 rpm Fujitsu MHW2160BH PL: 160GB, 5400rpm
Others: HDD: 160GB, 5400rpm, Fujitsu MHW2160BH PL, Realtek ALC262 HD Audio, DVD +/-R (DL) Toshiba-Samsung TS-L632D
2) I go to Start -> All programs -> Autodesk -> 3ds Max -> Change Graphics Mode and appears a window (file "2" in attachment!): which one I have to choose (Nitrous, Direct3D, OpenGL, Software)?
3) I set the properties of Bitmap as you tell me in your attachment, but I have the same problem.
"For general animation and rendering (typically fewer than 1,000 objects or 100,000 polygons):
Graphics Card: 512 MB or higher video card memory (1 GB or higher recommended)
System RAM: 4 GB RAM (8 GB recommended)"
That 'Conference Room' scene you are rendering looks very detailed.
Try all the options for display driver choices; Direct 3d, open GL and Software.
I think you need a better laptop though. 😕
Darawork
AutoDesk User
Hi, thanks for supporting me, I try all others options for driver but it's the same.
Now I'm installing 3ds MAX 2012 - that requires a graphic card of 256 mb and not 512 mb; I hope that the problem disappears..
