3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3ds max 2016 Visual C++ Runtime Library Runtime Error
30 REPLIES 30
Message 1 of 31
9169 Views, 30 Replies
Like it says.
This happens whenever I close the application.
3ds Max still running in Task Manager Processes and Microsoft C++ Visual Runtime still running in Task Manager Applications
 Shutting down 3ds Max in Task Manager Processes closses all.
30 REPLIES 30
Message 2 of 31
This only happens when Wacom Cintiq is on.
Message 3 of 31
Steve__Burke
I have the same problem and am using a Wacom Intuos Pro. I think you are correct that this is related to Wacom. In general, 3dsmax 2016 seems to make my tablet feel laggy especially when switching to other apps with 3dsmax running.
After closing max, I am using a batch file to kill the 3dsmax.exe process to stop the error messages.
killmax.bat
taskkill /F /IM 3dsmax.exe
Message 4 of 31
in reply to: Steve__Burke
The irony is I would not want to use the wacom for left hand navigation anyway as I use Space Pilot for viewport navigation.
But... I do need the wacom running at the same time, Zbrushing and Gozing to 3ds max not so fun with these errors cluttering up
Message 5 of 31
VishnuR
Hello everyone,
I'm gathering info and will send your issue to 3ds Max product development.
Please post here exact Windows OS and model of WACOM's you are using.
Will enter all that into the report for you.
10682566
VR
Vishnu Ramdass
Message 6 of 31
iadproductions
in reply to: VishnuR
Windows 7 64bit and Windows 8.1 64bit with Wacom Intuos Pro.
Mastering Autodesk 3ds Max 2013
http://www.amazon.com/Mastering-Autodesk-3ds-Max-2013/dp/1118129717/ref=zg_bs_4135_2
Message 7 of 31
Windows 7 64 bit
Wacom Intuos Pro with latest driver I could find: 6.3.11-4a
I get the same error message every time I close max. The error repeats until I force close the 3dsmax.exe process.
I DO NOT get the error message when I use max but DON'T touch use the tablet with 3dsmax (my tablet is always plugged in). Normally I use my tablet as my mouse. I have the touch features of my tablet disabled at all times.
I DO use a KVM switch to jump between different computers, probably not related but adding it as a data point.
Message 8 of 31
RobH2
Same issue here.
Wacom Intuos 5 Touch
Touch not enabled
I too use my tablet as my mouse
Latest drivers (as of 4/2015)
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 9 of 31
jens.diemer
Jamma247 schrieb:
Sometimes i get the same error, but i haven't any wacom, just a simple mouse.
Win 8.1 64Bit
EDIT: In windows system log i found some information, related to this:
Name der fehlerhaften Anwendung: WSCommCntr4.exe, Version: 4.0.3.0, Zeitstempel: 0x52e23951
Name des fehlerhaften Moduls: MSVCR110.dll, Version: 11.0.51106.1, Zeitstempel: 0x5098826e
Ausnahmecode: 0xc0000409
Fehleroffset: 0x00000000000740c4
ID des fehlerhaften Prozesses: 0x2a80
Startzeit der fehlerhaften Anwendung: 0x01d07da93d87114f
Pfad der fehlerhaften Anwendung: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr4\Lib\WSCommCntr4.exe
Pfad des fehlerhaften Moduls: C:\Windows\SYSTEM32\MSVCR110.dll
Berichtskennung: 744140cd-e9ae-11e4-826f-10c37b6d0bb4
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
 and:
Jens
https://github.com/jedie/3dsmax_bugs | https://github.com/jedie/3dsmax_patches
Message 10 of 31
joelgray
I get the same error when closing 3ds Max 2016.  Tried a reinstall twice and cleared out the registry entries, reboot etc.  The error does go away when I remove my Wacom as mentioned abobe (didn't think of that until I read it here).
Thanks for looking into this, Vishnu!
Joel Gray
Specs:
Wacom Intos Pro Small
Windows 8 64-bit, x64-based processor
30GB RAM
Intel Core i7-3930K @ @ 3.2 GHz 3.2 GHz
Nvidia GeForce GTX 580
Message 11 of 31
VishnuR
in reply to: joelgray
Hi Joel and everyone,
Thanks for your responses on this.
Am entering all your data into the report,
hopefully we can get some good movement on this.
I'll go bug some of you privately for your System Info .nfo files
so no need to post here if you if you're concerned about privacy.
# 10682566
Best Regards
VR
Vishnu Ramdass
Message 12 of 31
office
I get the same error with Max 2016 regularly too! Mostly after I exit Max and start it again. I don't have a tablet. Please check the attached screenshot:
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
Message 13 of 31
same issue as everyone else, just unplugged my tablet and it goes away.
Windows 7
Wacom Bamboo
Message 14 of 31
Sorry VishnuR for my manners.
I am running win7 64bit on an SSD with 6 gig ram. Running 3DS Max 2016. My Graphics card is GTX680 4 gig ram. I have wacom cintiq 24HD touch (model DTH 2400/K) and 3dconnection space pilot pro attached. All drivers are most recent.
Message 15 of 31
lightcube
I saw this error when I tried to set up 2016 to run all the plugins that I have in 2015. In my case, the error was one of these plugins: nPower Power Nurbs or one of and/or all of Afterworks plugins (Fume, Afterburn, etc). I manually added them to Max 2016 and was seeing this error. When I removed them from my plugins folder, the error went away. This isn't necessarily related to others seeing the error, but it may be helpful for the devs. I was just tinkering. (And so no one feels that the plugins are poor, it must be pointed out that I was just copying files from the plugins folder which might not be the entire installation needed for any of these plugins... and I did this before the plugins have been officially green-lighted for 2016.)
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Message 16 of 31
m1de23
Windows 7 Professional SP1 (64-bit), Wacom Intuos5 Touch with driver version 6.3.11-4
Message 17 of 31
jens.diemer
in reply to: m1de23
any news here?!?
Think this results in another the problem:
I start max and can't confirm the "open dialogs" like "other system unit" or "other gamma"... It's freeze.
Then i look into taskmanager and see there is another 3dsmax.exe... But this it the old closed one. So i kill the process and then comes the "Visual C++ Runtime Library Runtime Error"
Jens
Message 18 of 31
VishnuR
in reply to: jens.diemer
Hi Jens and 3ds Max friends,
I checked and here's a quick update:
This one is still under investigation, actually further along in testing.
Fix is still in the works, soon but no exact date set yet.
Sorry for any generic answers, that's about all I have now.
Good news is we're closer to a final fix , just need to be sure its not affecting other things.
Best Regards
VR
Vishnu Ramdass
Message 19 of 31
jens.diemer
It seems that this is the default response to all reported bugs.
This is why i love OpenSource development. Then you can really see what's happens, while AD is a black-box.
However, i found another bug that's related to this:
Sometimes i can't confirm the "File Load: Gamma & LUT Settings Mismatch" dialog on max 2016 startup. I see the dialog but can't click on "OK", because the whole max GUI is freezed.
This happens if there was a old "3dsmax.exe" process ended, but runs invisible because of the "Visual C++ Runtime Library Runtime Error"... Works-a-round:
  1. terminate the old "3dsmax.exe" process
  2. the "C++ Runtime error" dialog comes to front
  3. confirm the C++ error
  4. the new 3dsmax GUI is now not freezed
  5. Confirm "File Load: Gamma & LUT Settings Mismatch" dialog is now possible
Jens
Message 20 of 31
This is how it is in win10.
This time you can simply dismiss the error window without needing to task manager end task.
