I have the 2013 ultimate entertainment student suite or whatever the official name for it is (Contains lifetime student versions 3ds max, maya, softifimage mudbox, etc) and I went to use CAT for the first time, and I notice I don't seem to have it.
Is there any place I can purchase or download it?
Solved by Steve_Curley. Go to Solution.
You should have. As far as I know it is just part of Max, regardless of license type or whether it's part of a suite.
Are you absolutely certain the CAT Objects option isn't there?
If not then I've no idea 😞
Ah, there it is. It's only listed through the side menu, not through the tabs at the top of the screen.
I had previously used a version of max where it was listed via the top, too. I assumed that both create menus would have the same things regardless if accessed through the side or top.
