Hey guys,
Just imported a Zbrush sculpt as an .obj and wanted to see the wireframe in 3DS.
However wireframe mode is always a white sihouette.
Anyone know how to fix this?
Solved by Alfred.DeFlaminis. Go to Solution.
You could try changing the color of the wireframe, maybe it's just the vertices being soo super tight together that it looks like a plane.
Just assuming here though...
I can't confirm if this is what I was thinking about, because my 3ds max install just died recently, but i think it is.
Hello @genepawns098haha,
I'd like to help you with this. I have a couple suggestions and let's see if they take us where we need to go here.
As @Anonymous mentioned, it sort of looks like the model is set to wireframe and is too dense so the wires look flat. If this is not what is happening, then it just needs a material added to it and set the viewport to realistic or standard and make sure to turn off wireframe on shaded (F4).
If that STILL doesn't work, maybe it's set to display vertex shading somehow. (Super weird.) You could right click it, select Object Properties, and make sure that Vertex Channel Display is off. If THAT doesn't work, maybe you could attach a file here that is only say 50 polys of the model (a tiny section of the neck or something) so that I can check it out and get back to you quickly.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Glad to hear it! In Maya that is called "Wireframe on Shaded" view, in 3ds Max it's simply called "Edged Faces". The hotkey for it is F4, or you can go to the menu listed below:
Is there a way to reduce the poly count in 3ds?
Even on edged faces mesh is so dense it still comes out as a solid color until i zoom in to see the polys.
Well, yes... but I have my doubts as to how effective it will be compared to say something like decimate in Zbrush for a model this dense. But you can try it. Here and here are two links that may help you with this. I think the best bet is to not use the super high res mesh in 3ds Max, but maybe export a lower subdivision with displacement or normal map exported out of Zbrush. I understand the process but I don't do much Zbrushing...
