Hi I was wondering if anyone could help me. I want to make curls like this in 3ds max and was wondering what modifiers would be used to do this? Thanks 🙂
Hi Doohoo.
I have attached a jpg and max file to this message which i hope gets you some way to what you are wanting to achieve.
I have used a taper modifier to get the mesh to taper towards the end, and have then used a twist modifier to get the twist. The center of the twist modifier has been moved slightly to allow the mesh to give that twisty tunnel effect and I have also rotated it slightly so the the thinner end do not have such a large twist.
Hope this helps 🙂
Hi Andrew. Thanks but when try to make it more like a spring shape it all gets messed up. The twist modifier curl doesn't seem the same as this one below, It seems more like a spring but using modifiers?
