3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
What is this?
2 REPLIES 2
Aikiguy
271 Views, 2 Replies
What is this?
Hi
Can anybody tell me why 3dMax does this?
I have modelled, unwrapped and textured a character but wanted to insert some loops in the fingers and I keep getting this happen.
Every time I add some loops with swift loop and try and remove some older loops in the fingers the shading appears to go strange and then pressing ctrl+z to undo causes part of the model to look like the image above.
Any help would be greatly appreciated. Thanks
2 REPLIES 2
StephenMF
in reply to: Aikiguy
OK... I have seen this before, often when importing FBXs or getting a mesh from Mudbox or something similar.
I can't tell you why it is happening, but I think I have a workaround that can fix it:
*Collapse the object to an editable poly.
*Switch to sub object level polygon or ellement.
*Select all
*Detatch (as clone)
*Delete old bad mesh
*Rename new mesh to the original name
Let us know how it goes.
Enjoy.
Stephen
M_atherton88
in reply to: StephenMF
I tried your suggestion and it worked. Thanks Stephen.
