3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Viewport lag in quad view, not in single view
9 REPLIES 9
Message 1 of 10
y-p
1048 Views, 9 Replies
I already posted this at CGTalk but unfortunately didnt find a solution:
even in an empty scene my framerate in the quad viewport is about 7, 8 but in single view its 30-40..
I'm a little unsure if it was low like that before and I just realized now or sth. has changed.
(Guess it has not been so slow as its really annoying)
Using latest NVidia drivers and a 3DConnexion Navigator with 3DS Max 2013.
Any idea why?
9 REPLIES 9
Message 2 of 10
y-p
in reply to: y-p
No idea anyone?
Maybe one how I could get closer to solve this issue?
Message 3 of 10
dom2207
in reply to: y-p
I had the same issue, I guess it's a lag from the 3dconnexion drivers, just press "D" on each other viewports ( this will deactivate update on viewports ), not a solution, but it can help.
Message 4 of 10
spacefrog_
in reply to: dom2207
My explanation would be that the 3d Connexion drivers cause a massive increase of viewport redraw calls, which of course slows the whole viewport down a lot.
I bet you will see a slowdown with those drivers even in single maximized viewport, but not such a large amount..
Would be interesting to see what happens when you disable your 3d connexion drivers completely. You might experience a whole new world of fast viewport 😉
Message 5 of 10
dom2207
in reply to: spacefrog_
You're certainly right, but the 3d mouse is so useful ...
Message 6 of 10
y-p
in reply to: y-p
Thanks for these suggestions and sorry for replying late!
Disabling the viewport didn't change anything and yes, I cannot leave my 3D mouse, no way 🙂
I tried it at some other computer with a similar setup, even a lower quality graphics card- smooth like baby butts even in high poly scenes.
Actually this is where a 3D mouse shines, it handles packed scenes better and smoother than the normal navigation..
So I have to find the error somewhere else...
Had a neighbor watching my pet when I was on holiday- who without permisson started my pc (what a **, cant tell how much I hate people on my office machine..!) installed a game (!) and changed some NVidia settings (lower monitor frequency and whatever else) because "it did crash all the time" (can you imagine how much this s**ks?? Some people are just crazy..) and I am quite sure it has sth to do with it. Never change a running system. Hard to change back things if you dont know any history of changes..!
So im lost with anger and errors 🙂
Learned my lesson and set up a master password.
Message 7 of 10
phillip
in reply to: y-p
Hi
I am having the same issues, with objects just freezing and not being able to move them.
The cross hair moves and snaps but the object itself just stays put.
I am installing the latest update no 3, I hope that dose something.
I have restart max when this happpen.
Please can you get it sorted.
Pay enought for this product, and while I am at it, can you issue my subscription activation key please its been a neary three weeks now waiting.
Philip Kelly.....sketchrender
Message 8 of 10
y-p
in reply to: phillip
Well.. maybe you pressed spacebar and locked the selection. Look for the little lock symbol in the lower toolbar if its activated.
For your activation issue I guess you should place this question in another thread or try to contact Autodesk directly, maybe using the chat..
To finish this topic: I found a, maybe the solution for this very unique problem.
That guy had installed a certain "Nvidia Inspector" helper tool to change settings of the card. There is a option to limit framerate to a specific value. This is stored on the graphics card even if the helper tool is deleted..
I resetted all values to default and it seems like its working as it should.
Still you can imagine how uncomfortable he felt 🙂
So if your hardware is not from some really old days it should be a smooth working in quad and full with 3D mouse, even though in single viewport it will always be quicker!
Anyways, happy.
Message 9 of 10
phillip
in reply to: y-p
Ah now, I have been using the software for years.
There a number of glitches in the Max 2014.
Found another one today the draw polyline too, won't let you draw a point and insists on closing the polygone for you .
Sever pain in the A**.
Fed up with the so called upgrade.
Phil
Message 10 of 10
phillip
Also the snap 2.5 and copy ie hold down shift, doses not work.
Also a big problem.
Can you sort that too please......Autodesk.
