I'm trying to create a vertical cylinder for a cars wheel arch and when i drag the cylinder out, it is dragged out in horizontal instead. HELP. its probably really simple but its frustrating because if its a setting i dont know how to change it.
Thanks in advance!
Along with Steve's advice, I will add another option. If you create a Grid helper object, right click and activate it, you can rotate it and move it around. When you create a new object, it will align it's origin with the Grid object. So in your case, make a grid and rotate it 90 degrees so that it is aligned with where you want the cylinder to start and the orientation. Then create your cylinder.
I don't use grids too often, but they are invaluable when you are building to an odd sloped surface or even want to create objects higher than 0 in the z direction.
Chris Medeck
