3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Unable to use ViewCube with DX10
4 REPLIES 4
341 Views, 4 Replies
Hi all,
i found a probable bug in 3D studio max 2010 x64.
My Video Card supports DirectX 9.0 and DirectX 10.
If I work with DX 9.0 I can use the ViewCube but, if I change the Direct3D version from 9.0 to 10, the ViewCube disappears from viewports and I can't enable it from "Views" menu.
First image represents Direct3D 9.0 settings. You can notice the ViewCube on the upper right corner.
Second image represents Direct3D 10 settings. There is not ViewCube on the corner.
Finally, third image represents the "Views/ViewCube" submenu. There is no options.
Here is my Computer specifications:
Operating System: Windows 7 Ultimate x64
CPU: Intel Core i7 860
VGA: XFX GeForce 8800 Ultra 768MB DDR3 - PCI-Express 1.0 (DX9 and DX10)
RAM: 4GB DDR3
Thank you :)
4 REPLIES 4
Steve_Curley
1) Switch to DX9 - DX10 is flaky at best.
2) Please do NOT post in the "bugs thread" until your issue has been confirmed by other users. All 9 of them (so far) have been removed from that thread. The rules for posting there are very clear.
Posts with no links to a discussion thread will be removed on sight with no prior notice given.
Posts with links to discussion threads which have no replies, by other users, confirming the issue (yet) will be removed on sight with no prior notice given.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Is that with the service packs and hotfixs installed?
I have the same problem. Win 7 x64/3ds max 2011 x64/dx10 (q9400+4 gb ddr2+ati hd5750 1gb ddr5+at least the 2 last driver ver of catalyst).
Max work fine with dx9 and opengl, but not in the dx10.
Max does not support DX10, it does support DX9.
If you choose to use DX10 with Max you will have problems.
Use DX9.
