3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
There are no caustic photon emitters in the scene
4 REPLIES 4
7383 Views, 4 Replies
Hello people,this may be a repeated question but the problem is little different.
I am working on 3ds Max & my project consists of
1.A simple plane with "Recieve caustics enable"
2.A torus knot with a glass material and "Generate caustics enabled"
3.A mr Omni light source
In render Setup,"Caustics" and "Final Gather" are enabled.
But still if "Render" is clicked,an error pops up-"there are no caustic photon emitter in the scene"
What am I missing & what should I do?
4 REPLIES 4
Assuming you are running Max 2011, you need to activate Generate Caustics for the Light in the object property menu; it is no active by default.
ivan
Edit: Sam was just a second faster than me. 😞
You must enable caustics for the light too.
We must have hit Submit at the same time.
i am new on 3ds max. when i am going to render the project there is a message appear that there are no photon emitters in the scene. what its meaning?
