Inside the Terrain setting, there are 2 options
1) No Simplification
and
2) Interpolate Points * 4
What is the best setting to have a more realistic and detailed terrain?
more info here: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
I know this information, but I did not understand what is the best setting to have a more realistic and detailed terrain
No Simplification or Interpolate Points * 4 ?
There is no definitive answer. The best choice is whatever method best fits you needs and creates the best-looking/most-efficient mesh for that particular model.
Try the various settings, and see which you like.
Another trick to try: Apply a Normalise Spline to the contours before the terrain, and adjust its length value to create a nice terrain mesh. That can help if the contour splines have uneven vertex density or edge length.
