3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
save as archive and max version text
7 REPLIES 7
Message 1 of 8
Pixelschmiede
4445 Views, 7 Replies
if I want to save an archive to an older max version this is almost impossible because I don't see the right version... http://c2n.me/72jGP2.png
is this fixed in the next version?
thanks
themaxxer
Tags (2)
7 REPLIES 7
Message 2 of 8
You can only save up to 3 versions back from the one you're using.
Max 2013 can save as 2012, 2011, 2010. Max 2014 can save as 2013, 2012, 2011.
This is likely because the Subscription Licensing allows you to continue using up to 3 previous releases and so the number of available previous versions is not likely to change. 2015 will probably allow 2014, 2013, 2012.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 8
yes I know and that's a nice feature of max... but taht's not the point. have you checked the link http://c2n.me/72jGP2.png
if you want to archive then you can not see which version you will save... that's the problem!
best regards
themaxxer
Message 4 of 8
darawork
in reply to: Pixelschmiede
confirmed here too.
As a workaround usually what I do is save the whole scene as a previous version, open that and then saveas archive.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Message 5 of 8
😮 I did look at it but didn't notice the missing version numbers, sorry. It's the same here btw.
Report it as a bug. They're probably in the same sequence as in the File > SaveAs (current version at the top of the list).
Max 2016 (SP1/EXT1)
Message 6 of 8
lightcube
in reply to: Steve_Curley
Yes, this has been a musical bug for me. I have decided to always assume that I've saved the correct version. But my favorite solution is just tell others to update to my version of Max 🙂
Shawn Olson
Developer of Wall Worm
3ds Max plugins and Scripts
3ds Max 4/Gmax - 3ds Max 2020
Mudbox 2009-2019
Windows 10 x64
i7 8700K
64GB RAM
Geforce 1080ti
Message 7 of 8
BenBisares
in reply to: lightcube
It is a bug just not the one you're thinking. Basically the Archive tool doesn't support the save to previous functionality. The bug is that you have 4 options in the drop down which are all the same.
That being said I logged a wishlist for this on your behalf because it would be nice if it did support previous versions.
As a workaround you could do a normal "save as" as the version you want and then use that as a replacement for the max file in the archive.
Also for those of you that may not already know, if you want to make a suggestion or have an idea of how to improve max you can submit there here:
http://3dsmaxfeedback.autodesk.com
or
Ben Bisares
Message 8 of 8
PROH
in reply to: darawork
Hi darawork. You need to do it the other way around, otherwise you'll end up with a v2014 in your archive.
1) Save as Archive (zip)
2) Open the Archive and open the Max file
3) Save As previous version (i.e. v2012) and overwrite the v2014 file in the Archive
4) Close the Archive (zip it)
This is how I do it - quite similar to Bens suggestion.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
