hi, changing the location of north doesn't seem to help because viewcube always rotates the view 90 degree and i need it to rotate only 45 degrees. is there a way to set the viewcube rotation increment? thx.
I have investigated your request on having the Viewcube rotate by 45 degree increments.
This is now logged as a feature improvement with our engineers.
Good idea to have option to control the amount of degrees.
Thank you for taking the time to submit this.
Best Regards
VR
IMHO never use the viewcube... Just disable viewcube...
use a camera?!?
I don't know what "UCS system" is and i don't really understand what you needed...
Maybe: Create a new grid object, rotate 45° and use it as a grid?!?
Using Grids: http://help.autodesk.com/cloudhelp/2016/ENU/3DSMax/files/GUID-9666CF2E-BDAD-4148-86FB-17E5477D0426.h...
(But i never would model objects rotated to 45° 😉 )
The view cube has 6 sides, 8 corners, and 12 edges. If you are viewing one of the principal planes (front, right, ...) then clicking on one of the view cube edges will rotate the view 45°. If you are viewing one of the edges then clicking one of the principal planes will give yield a 45° rotation. The eight isometric views are accessed by clicking one of the view cube corners. You can make a 45° rotation from an isometric view to of the other view cube standard views by clicking the appropriate edge or side.
You may want to set the view cube default to orthographic (not perspective) and uncheck Keep Scene Upright in the ViewCube tab of Views, View Cube, Configure... .
This may not be the easiest method for viewing an angled wall straight on but it works!
