Solved by adavies. Go to Solution.
I was getting a pink noise glitch in my renderings.
I had imported objects from revit and rendered with vray.
Come to find out that some objects were corrupt.
I deleted the corrupt objects and it rendered fine.
i am having the same problem going from revit to 3ds max - how did you update and remove problem items?
Most likely an issue with Autodesk materials. Try running Vray scene converter (right click > V-Ray scene converter).
If that doesn't work,use this free script:
http://www.scriptspot.com/3ds-max/scripts/material-converter-v0-98b
Good luck.
Try the following
1) Optimize Scene Size (If you are not confident enough then move to step 2)
2) Save the file and close the file.
3) Open a new blank scene
4) Import your problem file into this new blank scene file.
5) Try rendering again.
Best of luck.
