Seasr All,
I would like to submit You a couple of issues:
Issue 1 - While rendering with a mental ray scene created with 3DS Max 2016 if I cancel the production rendering, Max 2017 crashes during the cleaning up and closes automatically. It is pratically unusable... If I re.start the application does not reopen the file giving me the classic error.
The configuration of my HP Z420 is very respectable and graphics drivers are updated to the latest version, However I tried with another workstation (even with Windows 8.1 while Z420 hasd Windows 10). It happens with Nvidia mental ray render... I tried with ART: no problems.
I point out that, if I open task management still see the active application even though it is closed.
Issue 2 - 3Ds Max 2017 does not read my previous proxies...
This happens with both Windows 8.1 to 10.
Thanks in advance.
Lino
Solved by Alfred.DeFlaminis. Go to Solution.
I can confirm this issue also. If I make an MR Proxy teapot in Max 2016 and place that proxy in Max 2017 in a standard scene and try to render with Mental Ray Renderer, Max crashes immediately and the 'Error Report' feature does not even come up to report it.
What's also odd is that the first time I tried it I thought that maybe I'd try a different viewport template. So, after that first crash I clicked to use the Outside template. Upon loading it Max crashed. But I did get the Errror Reporting feature. That's when I reported it. However, now every time I try to use that Outside template, Max immediately crashes. I've never used that template before so I'm not entirely sure it was caused by the proxy issue but I certainly can't use that template.
However, I have reported it to Autodesk. If you do get the opportunity to report it after a crash, do fill it out and report it. It will get read.
Rob Holmes
Strange: I think the "decoupling" MR from max should result in more stability... Why can max crash without CER here?!?
...I am quite sure that this problem is depending to mental ray proxy 'cause whenever i cancel any proxy from the scene, everithing is working.
Is the problem dipending fro the new mental ray plugins or is it a bug in 3ds max 2017?
Anyway, I hope this problem will be solved soon. I would like to use my proxies...smileysad:
Thanks. Lino.
P.S: the crash doesn' report any eerror, but when I re-open the same scene with proxy I get error message because the scene is still open in background.
I just wanted to chime in and subscribe to this thread. I'm having the same issues with Mental Ray Proxy crashing max when terminating a test render. In fact, Mental Ray Proxy isn't even in my create/Object panel... I found it in the drop down menus but it doesn't work.
It should be noted that I'm one of the people that installed Max 2017 and it didn't have the Mental Ray Installation option. I used a file provided here on the forums.
I'm in the middle of a project now and I'm afraid I may have to revert back to Max 2016 to finish due to this issue. Keep me posted guys.
Thanks.
Joel
I am having the same issues with proxies brought over from 2016 files.
Has this been resolved yet? Trying t avoid going back to 2016.
I'm also having this problem. The only work around is to recreate the proxies from scratch in 2017, BUT THE POINT CLOUD DISPLAY OPTION DOESN'T WORK!!!! All I get is the bounding box and the "show point cloud" does nothing. When placing cars and plants I need to have some idea of where the object is within the bounding box..
Seasr All,
Issue 1 - While rendering with a mental ray scene created with 3DS Max 2016 if I cancel the production rendering, Max 2017 crashes during the cleaning up and closes automatically. It is pratically unusable... If I restart the application does not reopen the file giving me the classic error.
Thanks in advance.
Lino
DEAR ALL,
DO YOU REMEMBER THIS PROBLEMATIC ISSUE?
K THAN: AFTER 3 DERVICE PACKS INSTALLED THE PROBLEM HAS NOT BEEN SOLVED!!!!!!!!!!!!!!!!!
DO YOU HAVE THE SAME PROBLEM OR DID YOU DISCOVER THE SOLUTION?
ANY REPLY WILL BE THE MOST APPRECIATED, SPECIALLY IF THE REPLY IS COMING FROM AUTODESK.
YHANKS IN ADVANCE.Lino.
Hello @all
I just wanted to let you all know that I am totally aware of these issues and I have been following the thread. I sometimes don't post if I don't have a solution to a problem, but I can see that this isn't the best practice in times like this when you are all looking for confirmation that you are being heard.
I assure you, you are. Part of the problem is that the SDK for mental ray this year isn't out yet, and obviously that causes some problems. The other issues are on Autodesk and are logged in the bug tracker already.
Regarding the mr Proxies, there is an issue loading proxies from earlier versions into 2017. If you make your proxies in 2017 they should work for you, but from earlier versions it's a problem. I realize this causes some pain for a number of people, but simply regenerating those proxies from 2017 should allow you to continue.
I realize this post may not be met with enthusiasm, and I understand. I can only assure you that these bugs are logged and that Autodesk is aware of the issues.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I will have to keep using 2016 until this is resolved. Please keep us posted.
When I installed 2017 (as part of design premium suite) mental ray did not install and was not listed as an option anywhere to install.
I had to go digging through the installer files to find the mental ray installer and run it after the fact.
Now anytime I have issues I don't know if it's an issue with the software or my installation.
Hello @CNATWOOD,
It is in there, you just have to scroll down when you are choosing your install options. Previous versions of Max didn't have that many options, and may people didn't realize that you could scroll so your issue isn't uncommon.
Best Regards,
DEAR ALFRED,
I tried in several ways to regenerate my proxies with 3DS max 2017 without any success. The matter is the following: AFTER THE CREATION OF THE PROXY ITSELF, I CANNOT SEE ANY POINT CLOUD, SO THAT IT MAKES ME UNABLE TO APPLY ANY MODIFICATION TO THE OBJECT. IT IS PRATICALLY UNUSABLE.
I followed the procedures step by step. No way! Is there any trick, may be?
This matter is so important for me and many other users like me. Can You help me, please?
Awaiting to hearing from you soon, I remain.
BST RGDS. Lino.
Hello @Lino2,
Yes, there is a problem with the point cloud display for mrProxy objects currently and the bounding box view is what needs to be used for the time being. It's logged in the tracker and being looked at.
Best Regards,
Hello @Alfred.DeFlaminis
We have run into the same issue with MentalRay proxies and are currently in production on a couple of shows using Max 2017. Can we get an update on if/when there may be a fix or workaround from Autodesk on this issue please? Like others on the list, we have an extensive library of proxy assets where the idea of updating each one individually is a prohibitive solution on a production schedule.
