Hi!
Im using 3ds max 2015 and I have a problem with reflection on a material. As you can se on the couch and chairs is there som bright spots and it is noise. The material is leather that I found in the material library in the program. I have tried incresing the image precision and glossy reflection but it does not help. Do anyone know something I can try to get rid of this problem?
Solved by PROH. Go to Solution.
Hi, Im using NVIDIA mental ray. The material is a Autodesk Material (leather) and Im using Photmetric lights.
But which do you mean?, reflection or refratction?
I have a new problem now. The mr a&d leather i scaled up and i cant scale it down with a UVWmap. As you can se materials anit my strong side. Any sugestions?
