Hi!, I just installed 3d Max and I have encountered a problem in the material editor, since in the Material / Map Browser appears not map any bitmap and style. No may be happening.
This is the view that the program gives me when I try to add a map:
If someone could help with this issue would be very grateful, do not understand why this happens.
Thanks!
Solved by eric.paris. Go to Solution.
Hello there...
I have the same problem... Have You found any solution?
Thank you I wait for your response...
Yea, I have the exact same problem. With the slots being a light grey, and the map browser being very wierd and not responding. Email me PLEASE if you found a solution: JoeyEvans21@hotmail.com
I have the same problem did you find a soultion I really need help ASAP !!!
Hi, in the material/map browser, click on the black arrow on the top left corner and make sure everything you need is selected ,for example, materials, maps etc...
An other thing you can try is to reset 3ds max to default: https://knowledge.autodesk.com/support/3ds-max-design/troubleshooting/caas/sfdcarticles/sfdcarticles...
Hello @aprsferragut,
I just wanted to follow up here and ask you if you resolved this issue. Is it working properly now?
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I have an issue I can not see my saved picture while adding them in the material editor
