hey all,
i recently started working with x-ref objects, so i'm new to this aspect of max.
i have an x-ref object in my scene and i can't select it in the viewport with all the regular tools like "select and move etc"
so i can't move it or rotate, or add modifiers or even delete it.
what am i doing wrong??
than'x
good week
guy
If you're like me and accidentally clicked "XRef File" instead of "Merge File" when dragging and dropping another model into your scene, you can go to File (or Application Menu for older versions) > Reference > XRef Scene and then a dialog box will open and you can select and delete the XRef that you accidentally added to your scene. Hope this helps.
