Hello
I am having a problem extruding a DWG file in 3DS Max. When I select the extrude modifier and give it an amount I can only extrude the splines and not the area enclosed within them. Here is a screenshot of what I mean.
I want to extrude all the blue areas in this drawing which I highlighted. I am trying to design a level so I want the grey area to be the characters path through it and the blue area to be the floor and ceiling. Im new to AutoCad and 3DS Max so I dont know much about them.
Personally I'd extrude in AutoCad and then import the dwg afterwards.
A tip for AutoCad; Type 'bo' to bring up the boundary region tool. Click in the middle of the shape and it will create a closed polyline boundary automatically. Then simply type 'ext' (shortcut to extrude), 'L' (to select last created entity) then the enter the extrusion height.
If you need to modify the extrusion in Max you can still get to sub-object level and move the grip nodes around.
You can only modify an 'imported' dwg. A file linked dwg is basically locked down until you right-click and convert to editable mesh/poly.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
