I have been searching for this for a while and just cant find anywhere. In Customize user interface menu option for setting hotkey for "Preserve UV´s" toggle. I doubt if it eaven exist.. I managed to make custom toolbar and added there two buttons for "$.preserveUVs = off" and "$.preserveUVs = on" but I would like to have it in my custom shift + rclick quad menu. Also having two buttons for this seems abit wierd. Could someone help me how i can make Quad menu or just set hotkey for Preserve UV´s. I use it a lot.
Solved by RGhost77. Go to Solution.
macroScript myScript category:"myScripts" ( if selection.count == 1 then ( try ( if selection[1].preserveUVs == off then selection[1].preserveUVs = on else selection[1].preserveUVs = off)catch() ) )
something like should be...
Thanks for the reply. That seems a bit complicated. I am not so much into max script. Didnt get that script to work.
1. Save this code to text file
2. Rename to myscript.mcr
3. Maxscript ->Run script (or drag .mcr to viewport)
4. Customize ->Customize User interface -> Category -> myScripts -> myScript (assign hotkey/qud/button or else)
