As a 3ds Max Design novice, but trying to get the most from my Building Design Suite subscrition, is there a simple reason why the planting which I included in my Revit model does not appear when imported into 3ds Max design? It is probably something that need sto be turned on but I am struggling to find it.
are you using archvision rpc content in revit?
DarrenP
Yes I am. Have since seen some posts regarding an issue with this but have tried following some of the workarounds with no success. Help would be much appreciated.
i believe if you installed the arch vision plug in for 3ds Max the plants will come in
i think this is a licensing thing between Autodesk and Archvision that they are only allowing Revit to use the content for free
DarrenP
