I have found that MultiRes often crashes Max when you press the generate button.
Attached is an example scene with a simple mesh. If you apply a MultiRes modifier to it, press Generate, then press Generate again, it crashes Max.
It has happened in the past too with other meshes.
I am trying to figure out what it is about some kinds of meshes that crash the MultiRes Generate function.
Common steps that have not solved any problems:
# Reset XForm
# Convert To Mesh then Convert to Editable Poly
You may ask why not simply refrain from clicking generate twice. The reason is that I discovered this while troubleshooting game export tools where the MultiRes modifier is programatically told to Generate at different points for various reasons. The automated functions do not know if it was ever already generated.
I know many people will suggest using ProOptimizer (which I often do) but the functions I'm working with are being used by people who don't always have access to ProOptimizer... and there are times where MultiRes actually makes better results.
So, are there any ideas about what things cause MultiRes to crash?
multires_mesh_crash.zip
