3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Motion Blur in Mental Ray
5 REPLIES 5
Pyro777
350 Views, 5 Replies
Hello everyone,
I'm trying to apply motion blur to rotating fan blades. This will be rendered out as a single frame still image.
The look I'm trying to accomplish is to have the leading edge of each blade be not as blurred as the trailing edge. (like the attached race car image)
Iv'e tried the motion blur in the physical camera and it looks identical to the "camera Effects" version.
Ideas?
Dean
Max 2019
Win 10 64-bit; Dual Xeon E5-2699 v4 @ 2.20 GHz; 64 GB Ram
NVIDIA GeForce GTX 1080
V-Ray 4.02.05.00001
5 REPLIES 5
iadproductions
in reply to: Pyro777
Dean,
I don't know if you are a photographer and already know this, the effect your are describing is a very difficult photographic technique that involves precisely timed strobe flashes that go off a fraction before the shutter closes, so the moving object looks sharp.  Also, the sample image you posted I am farily certian is a toy car, and the 'motion blur' is photoshoped.
Now, if you are using mental ray as your render, you can go into the Camera Effects rollout of the Renderer tab and move your Shutter Offset back more, so if your Shutter Duration is .5, make your Offset -.4  so the blur starts nearer the beginning of the fram than the middle.
I hope that helps.
Mastering Autodesk 3ds Max 2013
http://www.amazon.com/Mastering-Autodesk-3ds-Max-2013/dp/1118129717/ref=zg_bs_4135_2
Pyro777
in reply to: iadproductions
Thanks for the reply! I am a photographer 🙂 Yep, you described it perfectly. (Rear curtain sync) Anyway...I'll play with the shutter offset a bit to see if I can create what i'm attempting. The only other way I could think of is to compose 2 images of the fan blades in photoshop.
Thanks for your time!
Max 2019
V-Ray 4.02.05.00001
iadproductions
Dean,
I hope the Shutter Offset setting works for you.  I almost suggested rendering in passes and composting the images, but I don't think any of us want to work that hard.  😄
Pyro777
LOL, very true!
Max 2019
V-Ray 4.02.05.00001
Pyro777
I ended up having two sets of blades. One was stationary and one had motion. Put one infront of the other and render out...worked well.
Max 2019
V-Ray 4.02.05.00001
