Area :: Header
New tools, templates and workflows
Announcing Extension 2 for 3ds Max 2015 and 3ds Max Design 2015
Discussion Groups
3ds Max / 3ds Max Design General
Active Member
0 Kudos
Missing face in render
63 Views, 9 Replies
03-02-2013 10:19 AM
Hey there!
I'm pretty new with 3DS Max so I keep bumping into errors I can't work out. I've currently got an issue where faces aren't showing when rendered. The object doesn't easily allow me to use swift loop either. Any ideas?
EDIT: CHECK LAST POST PLEASE!
Moderator
510 Kudos
Re: Missing face in render
03-02-2013 12:26 PM in reply to: BraXzy
Your model is partly inside-out. Select the model, right-click > Object Properties, turn on Backface Cull. You should then see the same in the viewport as in the render. Any polys you can see the "inside" of need to be selected and flipped. You may find it easier to select those you CAN see the outside of and flip them, then select all (Ctrl+A) and flip the lot.
If you can't fix it, remove everything but that model, save it as a new scene (so you don't lose the original scene), zip it then attach it to a reply so we can take a look at it.
Max 4.2 through 2015 (SP3+EXT2), Composite 2014.
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 335.23).
Active Member
0 Kudos
03-02-2013 01:30 PM in reply to: BraXzy
Hey thanks I think I've got it fixed it seems fine in render and I can swift loop it now (I moved the extrusion to the other side of the "middle" and then flipped it)
Now I'm at a rookie wall I can't get over and it must be so simple.. I made an object that went a bit wacky and when I deleted it my viewport was in the middle of nowhere, can't find the rest of my scene.
What do you press to move to the centre of the "world" so to speak?
Moderator
510 Kudos
03-02-2013 02:23 PM in reply to: BraXzy
There's a couple of buttons, bottom-right of the main window, controlling the Zoom. One is for the current viewport, the other for all viewports (the right one of the two). Click/hold that one and select the upper of the 2 flyout options,then click the button. That should center the scene in all the viewports. You may need to zoom in to get to the origin.
Or just create an object (a small box will do), move it to the origin by right-clicking the spinners at the bottom of the Max window, then repeat the earlier suggestion but select the lower of the 2 flyout options (zoom extents all selected ). Then delete that temporary object.
Active Member
0 Kudos
03-02-2013 06:27 PM in reply to: BraXzy
Rather than make another thread thought I'd ask in this one..
I now have the problem that one of the objects I have made completely messes up when I remove turbo smooth, yet renders normally and the verts are shown in the right place, any ideas?
Moderator
510 Kudos
03-03-2013 02:14 AM in reply to: BraXzy
I'd suspect the order of modifiers in the stack is the problem. Assuming there are are 2 of the objects in the image, either side of the main model, then I'd try changing the order like so:-
Mirror
Turbo Smooth
Symmetry
Editable Poly
As before, if you can't fix it, post a zipped scene with just the offending object(s).
Active Member
0 Kudos
03-03-2013 11:42 AM in reply to: BraXzy
Hey steve thanks for all the help so far, that last problem sorted itself out funnily enough.
Now I've got another one :/ never stops! Basically I want a pointed "Dagger" so to speak, but I can't have any tri's (Must be all quad's) and I don't know how to make it work the way I want.
It is basically a blade with a slanted edge and the end of it has a couple tri's. Any ideas?
Added the MAX file so you can have a look if need be
Another thing, I want the swift loop to go through the section following the bottom line if possible?
Moderator
510 Kudos
03-03-2013 12:09 PM in reply to: BraXzy
The file didn't make it - it must be zipped. See this post for help with attachments.
Active Member
0 Kudos
03-03-2013 12:50 PM in reply to: BraXzy
https://www.dropbox.com/s/9sz61nxamrn2kvo/Gun.max?m
It's already on dropbox so is this ok?
Moderator
510 Kudos
03-03-2013 02:51 PM in reply to: BraXzy
It's ok, though we normally prefer files to be zipped and attached directly to a post (not a comment). I'll have a look tomorrow (nearly 11PM here) though it may be tricky to get ALL quads with a shape like that.
