3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
mental ray maps error/warn messages
6 REPLIES 6
12sunflowers
977 Views, 6 Replies
I set mental ray render. When i first time open material/map browser and icons from maps are loading i have this error/warn message. Icons are black circles.
http://pastebin.com/raw.php?i=xWzwDA4J
6 REPLIES 6
PROH
in reply to: 12sunflowers
Hi 12sunflowers. Seems like every error is coming from the MetaSL materials, so what happens if you close the MetaSL rollout and then reopen the material browser?
Not a solution, but maybe a workaround : )
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
12sunflowers
Hi)
Everytime when i use any map with black circle i have new error message. Nothing depends rollout open or close.
12sunflowers
Just thought maybe Vray fault because he too have black squares but no error or warn messages?!
12sunflowers
Problem only with MetaSL maps. I can successfully apply it but every time i have error message
API 0.0 23 MB warn 302017: illegal argument "Component_falloff" for function call to "Component_falloff"
PHEN 0.7 24 MB error 051011: shader "Component_falloff" not found
PHEN 0.6 25 MB error 051011: shader "Component_falloff" not found
12sunflowers
Please check do you have this error?
http://youtu.be/42dvumWwMy0
Gelashvili
Hi bro! I am not sure that this is thesolution but,when I read the error messages I saw "shaders" and I think that this tutorial may solve the problem,because the tutorial is about mental ray problem,watch it,I hope this will be helpful 🙂
http://www.youtube.com/watch?v=Yutx0MGNlPg
