Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
meditfunctions.ms seems broken
After installing the new sp2 and ext2 on max 2016, I ran into a problem.
The A&D templates stopped working and I got errors from meditfunctions.ms in the script listener.
Can anybody help me on this issue?
This kind of errors are in the listener:
-- Error occurred in i loop; filename: C:\Program Files\Autodesk\3ds Max 2016\stdplugs\stdscripts\meditfunctions.ms; position: 3768; line: 117
--  Frame:
--   j: (color 0 0 0)
--   i: #EffectiveSelfIllum
--   called in Set_mrArchTemplate_ActiveMaterial_FromMaterialInMatlib(); filename: C:\Program Files\Autodesk\3ds Max 2016\stdplugs\stdscripts\meditfunctions.ms; position: 3776; line: 119
--  Frame:
--   strMtlName: "polished concrete"
--   mrArchTemplate_ActiveMaterial: 01 - Default:Arch___Design
--   matFromLib: polished concrete:Arch___Design
-- Error occurred during fileIn in "C:\Program Files\Autodesk\3ds Max 2016\stdplugs\stdscripts\meditfunctions.ms"; line number: 117
Property is read-only: EffectiveSelfIllum
No solution for now but a workaround:
Open the template library directly in Slate and drag the Arch&Design templates in.
Question: Are you on Win10 ?
On windows 7.
we found that solution as well and its a nice temp workaround.
Been trying all kinds of things but no solution atm
