I can't start the mental ray DBR satellite service !
Can somebody confirm this?!?
In this case, the 2017 release is complete useless 😞
Solved by jens.diemer. Go to Solution.
Solved by spacefrog_. Go to Solution.
Solved by lightcube. Go to Solution.
Hi! I didn't test it myself, as the german Version of the software is still not available...
But from your screenshot it looks like you have 2 instances of the MR-Sattelite service installed (one 2016 and one 2017)? And the 2016 seems to be running, you might need to deactivate it...
Think that's not needed... You can also have 2015 and 2016 installed and running... Every new version used other ports, so there is no conflict.
Why not? Just download the "all Language" Version, this include german, too.
I tested it: It's the same error, while 2016 is deactivated...
nobody with the same problem here?
Hi Jens,
Your report was escalated to an internal support case to us, so I'll be following up with you there. I may also be logging a defect report/change request on this, so I'll let you know.
Best regards,
Jon A. Bell
Autodesk Technical Support
zur Information: Ich kann den Service auf meinem System auch nicht starten.
Deshalb hab ich das an die Entwicklung weitergeleitet um das zu fixen.
Wann allerdings ein Fix zur Verfügung steht, kann ich momentan noch nicht sagen.
Viele Grüsse
This is incredibly ridiculous. This is not just a bug. A FINAL PRODUCT fails initializing the RENDERING ENGINE, which was for more than a DECADE the PRIMARY RENDERING ENGINE of the package... And nobody noticed THAT before launching the 2017 rocket. I just can't believe it. And we pay thousands of dollars to get answers like "we don't know when it will be fixed".
We're investigating this -- if an issue doesn't manifest in our own internal testing, then we have to go back and work to reproduce this.
I'm talking to some of our internal developers about this and I'll update everyone as soon as I can. Thank you for your patience.
Best regards,
Jon A. Bell
Go to the windows services file and change the text from 2016 to 2017 [just before the port number] to allow launching the satelite service. After doing this I now get an issue with can't find dll files when actually submitting a dbr for render on satelite machines. But at least it renders locally.
Appears to be an issue now that the Nvidia files install in the plug ins folder instead of ..3ds max 2017/nvidia.
I'm absolutely sure this problem is caused by the fact, that Nvidia and Autodesk are sulky with each other. Nvidia maybe wants more money for Mray and iRay and that's why now we got a by far not production-ready beta-ART - and Mray is just kicked out of 3dsmax and has become just another plugin. So nobody cared about Mray anymore - Autodesk focused on Art and Nvidia half-heartedly created that free version of Mray. That's how things got messed up. I'm absolutely sure that's what happened.
Meanwhile of course, Autodesk is happily collecting the quadrupled subscription fees from it's new customers. Now that is efficient business, isn't it?!
Hi guys, after some fideling i got a working solution for the satellites to render when using DBR in Mental ray
Please follow the steps exactly and it should work ( at least it does for me )
Please report wether this works for you or not
I was talking to @jon.bell earlier about a separate issue and he asked me about MR satellite working here. I haven't done and network rendering with 2017 yet, but was curious.
@Anonymous mentioned editing the services file. When I looked at my services file, I see this in it:
mi-raysat_3dsmax2016_64 7524/tcp #mental ray Satellite for Autodesk 3ds Max 2017
It is odd that there is not actual 2017 entry, but the 2016 entry lists 2017 in the comment. Mine may be odd because 2017 MR actually always failed to install and I only got MR working here by manually copying from another installation on another computer ... but there must be some bad logic somewhere to have edited that 2016 line to mention 2017. I'm only sharing this as informational.
@lightcube wrote:
@I was talking to @jon.bell earlier about a separate issue and he asked me about MR satellite working here. I haven't done and network rendering with 2017 yet, but was curious.
Yeah - seems that the 2017 MR installer simply has the "2016" instead of "2017" in that string ("mi-raysat_3dsmax2016_64") by mistake. One thing i failed to mention in my post above is, that if you have had the real Max 2016 mental ray satellite entry in the services file already, you should copy paste the line instead of plain editing. And edit the COPIED line then as i describe above.
I can't remember 100% for sure, but i think the MR 2017 installation has simply overwritten the original 2016 line ,,,
@spacefrog_ great job!
The next bug in max that user fixed faster than AD. Strange, isn't it?!?
...opensource would has advantages...
I put all together to a "one-click-fix":
Download this .zip: https://gist.github.com/jedie/6a21195f43eebf2c64734776f1633df3/archive/d8b86daf9d2e02188159a233f17ce...
Extract somewhere. It's included two files: max2017_mr_dbr_bugfix.cmd and max2017_mr_dbr_bugfix.py
Start the batch file max2017_mr_dbr_bugfix.cmd with admin rigths!
Source code: https://gist.github.com/jedie/6a21195f43eebf2c64734776f1633df3
(Still untested... Will test it later and add a "start service" later)
I moved the patch to a seperate repository, here: https://github.com/jedie/3dsmax_patches
direct ZIP Download: https://github.com/jedie/3dsmax_patches/archive/master.zip
I also change the script, so that the service will start and set to "auto" at the end.
Now i tested my script and it works fine.
Apply the patch, looks like this:
