I appear to be having a problem with Nested layers and Particle Flow.
If I try and select my PF Source oblect in the Layer manager Max locks up.
If I select PF Source object directly in the screen it is fine.
I am also using Frost but have the viewport update off.
Frost also locks up if I select it in the layer manager.
Any ideas?
Solved by damon. Go to Solution.
HI Damon,
I have done a quick test and created a PFsource and assigned the PFsource into a Layer of a Layer.
But I have no issues when selecting the PFsource either from the Layermanager or the Viewport.
See also my screenshot enclosed. Have I done something different than you?
Basically the issue is not known. Potentially this is a scenspecific issue? or an issue from any plugin?
Best Regards,
I think I have isolated the issue. Select Children was ticked.
Even thought the particles are not displayed it apears to lock up max and make it hard to work.
