Upon 50% of occasions max 2014 (2013 works fine, but i need 14) will crash whenever i open up the material editor and whenever i switch from compact to sltae. Any clue to why this is happening .
Also having same problem. New clean install of windows 7 and Max 2014. Try to open material editor causes instant crash. Anyone have a solution for this issue? Thanks.
Can you provide more information? System, drivers?
I don't have any issues in 2014 like that on over 70 machines.
Can you get it to crash with a clean scene? Is it just when loading a specific file? Or texture? Do you have a material library loading?
Same issue with me. Just downloaded SP5 hoping that this has finally been fixed -- NO SUCH LUCK!
It is really upsetting that such an expensive software should have a known BASIC issue like this since the release and not being fixed after more than a year... Only continous pointing fingers at "video drivers"... Disgusting!
I got around the issue by switching the renderer to something other than the default scanline renderer. Go figure.
In my case it makes no difference- MentalRay, Iray, Default renderes, all crash...
Thanks Steve. I'll do reading and digging when I get some free moments...
Kiss the feet of Q12 !!! I had this problem for awile and it was very frustrating.
I searched a lot and find something intriguing here at this post: http://www.actualtools.com/forum/read.php?FID=10&TID=3230
So, that guy is the actual hero but I am the second one because I take the time to update a couple of forum threads with this specific problem.
This is the solution :
I do have a second monitor !!!! And also I have installed the "actual multiple monitors" software.
When you open 3dsmax, press once the "M" key to bring up the material editor.
Go to your running "actual multiple monitors" or whatever multi monitor software you have and [pause] it from it's menu.
Then, back in 3dsmax, press M again to close the material editor window.
From now on, every time you will open/close that window, the error will not appear anymore.
(now you can [start] multimonitor).
But! It is a temporarry solution because it is linked to the running instance of 3dsmax.
In other words, if you restart 3dsmax, you must pause that thing again.
I solved this problem, might be specific to me but heres what I did.
The reason:
If you have Scanline renderer set as main renderer AND have downloaded vray materials and added them to your material library. Everytime you open the material editor, it will "render" the material in a thumbnail.
So! Since you have scanline activated, it cant render and hence the crash. If you change your renderer to Vray, it is able to render it because its a vray material, and boom. no crash.
Hope this helps.
Hey, i'm here to confirm working solutions i read above.
My problem was on 3ds max 2016 and Vray 3.2
When you open a scene with Vray materials, (to make sure you never ever have this problem on this max instance) you need to switch back from Vray Adv renderer to Scanline, and to Vray again, because even if Max shows he is using Vray as renderer, he is actually trying to cache thumbnails of your vray materials with Scanline, which is clearly a bug.
So yeah switch from vray to something else and come back to Vray and it should be working.
I don't know if there is a link, but it only appears since i have a vray mtl in my library..
Thanks guys for solving my problem.
