Thanks for the reply.
What on this page is exclusive to Design? http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=11007421
Is it just Exposure1 and Exposure2? Or is there more?
Why can't all this stuff just be put together in one package? Or why can't both versions be installed at the same time at the very least?
EDIT: Also, is the material editor in Design limited to architectural materials only? |
The Exposure videos shows the only difference between Max 2009 and Max 2009 Design.
They are otherwise the same program, running from the same '3dsmax.exe' binary.
The answer of your other questions is not as straight-forward.
In short, Autodesk wants to sell Max to all markets instead of having VIZ whose main advantage (like the Hitch Hiker's Guide To The Galaxy) was that it was slightly cheaper (but without the "Don't Panic" on the cover), and required more resources to develop as it had its own code stream that had to be constantly synced back and forth with the Max code.
Now Autodesk has a specifically packaged version of the SAME product for the two main areas (Entertainment and Design). Max 2009 and Design ARE the same software from a technical point of view. The Exposure feature was not added to Design, but rather DISABLED in Max 2009 to give architects an incentive to pick that package, which also has some other things like Tutorials, Default etc. specifically set up for that market, as well as that awful Autocad-style desktop icon. So this is mainly a marketing decision and not an engineering decision.
For exactly the same reason (as both are technically the same application using the same license, Registry keys and so on), the Installer cannot support both - just like you cannot install Max 2009 itself twice on the same system. Also, why would you want both on the same system? If you are one of those who need the Exposure feature, you would install Design anyway which will do everything Max 2009 does. If you are a plug-in developer, you most probably have access to a developer version of Max and the SDK from completely different channels, or could install Max 2009 on another machine for development purposes, or never install Design to start with, because you don't need the Exposure feature if you are a developer.
Borislav "Bobo" Petrov
