I just received a new computer from my university and they installed the 64-bit version. I had 2012 installed on my old machine and it had great materials in the slate editor but this version has none. Am I missing something or just out of luck with this version, or can I download the materials that came with the older version? Thanks
Hi. This sound extremely odd. We might need a bit more information to help you.
- Your old program was 3dsMax2012, and your new one is the 64bit version of what? (2013, 2014..).
- What OS do you have? (In case of path tracking).
- What happens if you open an old project in this new version? (warnings, missing bitmaps etc. or does everything look right?).
- Could you show us a screendump of the empty slate editor (especially the left colum).
This is 2013 version. I found the material libraries. They didn't show up with the scanline renderer but when I switched to mental ray they did. Problem 1 solved.
Problem 2- they don't render properly. I attached the box I made. This is suppose to be concrete blocks, it obviosly is not. Please help. What am I missing?
The compact mode works when I bring in a bitmap, but the slate editor won't render the autodesk materials from the library.
