I am working on setting up a mock photography studio with a typical roll out backdrop.
I have a picture of an actual mottled backdrop. I've created an Arch & Design material, wiring a bitmap of the backdrop to the Diffuse Color Map of the material. That might not be the best way but I'm a newbie so that's my reason.
I put a UVW map on the backdrop and then wired the Arch & Design Material to it. It renders as expected but the mottled material does not display in the viewport even though I did turn on Show Shaded Material in Viewport in the Slate Material Editor.
How would I get the material to display in the viewport?
In your Bitmap in Slate, you have the Coordinates set to Environ (Screen). You'll need to click the radio button for Texture. Since you've got your UVW map set to use Real-World Map Size, you'll also want to enable that in your map. This way, the size of the mapping is controlled in the Bitmap paramaters rather than through the UVW Map modifier. It is defaulting to 1" now, so you'll want to increase that accordingly.
Next is the UVW Map modifier itself. You have it set to Cylindrical, but if you look at the gizmo it is turned the wrong way to apply to your backdrop. Near the bottom of the modifier parameters is a section called alignment. It is set to Z, but you want it to Y. There was something really weird going on with that modifier, but after cycling through Box, Planar, then Cylindrical again, it seems to have corrected it's U Tile setting. It had been a million or more at the beginning, but now shows me a value of 347.184. I also toggled the Real-World Map Size checkbox a couple times.
The alternative would be to not use Real World at all, which may work better for you in this case. Then the tiling and size of the map is controlled mainly through the UVW Map modifier.
Let us know if you still have any problems.
And as an alternative method to create what you've got, I might suggest using a plane. Use Edit Poly to add more subdivisions at the point you want the bend to occur, apply your UVW Map, then a Bend modifer to turn up the back.
Chris Medeck
Hi camedeck,
I tried it again. This time I used the Studio template from Extension 2. It's the studio setup you can choose when starting 3ds.
I just put a simple box in there and applied a floral wall paper to the backdrop. It's "Wall Covering Wallpaper-Roses" Autodesk Generic materials. Why won't the wall paper pattern show up in the viewport? It renders, but I really want to see at least a facsimili of it in the viewport, with shadows cast on it.
File attached.
Steve's right, it works for me when testing with the scene.
See attached pic and where to click to enable it to appear in viewport.
