low res shadows in scene
Message 1 of 11
Can someone tell me what makes shadows stair step. Its like low resolution or something.
https://gyazo.com/1f35a14e3d250aadfb8c9b8807d20a16
Replies (10)
Message 2 of 11
leeminardi
If you are using Shadow Map it could be caused by a small value for the Map Size. Try increasing the map size or better yet use Ray Traced shadows. What renderer are you using?
~Lee
lee.minardi
Message 3 of 11
kgokhangurbuz
Hi;
Provided screenshot is from a viewport, seeing shadows in viewport like this is perfectly normal. If you want more precise shadows in viewports please follow these steps;
Click on viewport > Shading type (image1)
Go to Configure
Under Visual Appearance and style tab, you'll find Lighting & Shadows Quality (image2)
image1        image2
This will increase the shadow image quality in your viewports
Can you please upload a rendered image and give information about your render engine, light source types etc if you have shadow problems in renders too?
Regards;
Message 4 of 11
Thanks for your reply
My renders are always ok its just the viewport.
I changed my Lighting and Shadows quality to the maximum and it still shows a stair step effect in my shadows. Now here it the interesting thing. I made a line to point out the stair step affect and then the shadow goes a wait. If i delete the line it comes back. This is strange.
https://gyazo.com/a0039dd06eb4f12ab3c0f16a999574d0
https://gyazo.com/3b4c66e6631e607856fd694feda192a5
https://gyazo.com/0a7acf3b4f631822ab1e836d7cf0031d
I removed everything but this conveyor to make the file smaller to send. Not look at the shadows. they went from stair step to shutter effect.
https://gyazo.com/0b37a04d6e742daec86da014048b4b64
Message 5 of 11
kgokhangurbuz
Hi;
Well, having these kind of things in viewports are perfectly normal to me but i wonder what your display driver is selected as.
Are you using Nitrous, OpenGL or D3D?
Message 6 of 11
Nitrous
Well if it is normal to you then maybe I should not worry about it. Its strange because it is not all the time. Sometimes its fine.
Message 7 of 11
spacefrog_
there is one hidden setting regarding shadow quality in Nitrous viewports which is nowhere exposed in the UI.
It's the Nitrous shadowmap size limit which defaults to 512
To crank that value up, you can type the following in the maxscript listener ( 4096 being used as example here )
Nitrousgraphicsmanager.shadowmapsizelimit=4096
Do that in your scene you posted, and the artefacts will be gone.
Unfortunately this setting does'nt get stored in any config file, nor with the scene itself. Thus it resets itself with each 3ds Max restart. Though you could place the command inside  a script and copy that script to your 3ds Max scripts\startup folder  ...
 Or - for your convenience -  you could use my PowerPreview script, which provides a comprehensive UI to tweak your viewport setup for optimal quality ( or anyway you want it ). Just download from scriptspot
This is how the UI looks about
Regarding your scene viewport setup in general:
You are using the default lights with 2 lights in your viewport settings, not the scene lights. Default lights depend on your viewport camera position, the second light angle will be positioned even worse, thus you will have such shadow artefacts much more likely. In your case, the second light is placed pretty coplanar to some of your surfaces , thus the obvious artefacts
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Message 8 of 11
great info thanks!
Message 9 of 11
senorpablo
This has been hardcoded to 512 as long as I can remember. We now have video cards with 8GB of RAM, where 512MB was common when viewport shadows were first introduced.
I think it's time to up the default, or at least provide a discreet setting for it.
Message 10 of 11
Thanks for you input
Sorry just realized i did not reply
Message 11 of 11
earthman1970
I do not seem to have that tab in my configure viewport settings?
