I have inexplicably lost my side Menu with the Create/etc etc Tabs, and it would appear that I'm in Expert Mode but I am not.
I tried toggling Expert Mode but that does nothing.
I can't figure out how to toggle back to the side Menu and if anyone knows what might be the problem, I would greatly appreciate the help as I currently can't really use Max.
Daniel
Solved by Steve_Curley. Go to Solution.
Two tiny annotations:
- which button to press after Alt-Spacebar depends on your Windows localization. Here it's V for Verschieben. Right click the title bar of any programm...
- you only need to hit a cursor key once; after that, the window is glued to your mouse pointer. Moving the mouse moves the missing window on your screen instantly, which is better than guessing the wrong cursor key direction 🙂
Hi Steve,
So weird thing. I don't know what happened but when I relaunched 3ds Max this morning, the Command Panel (that's what the large side menu interface is called, right?), was back!
So weird...I distinctly recall resetting Max and nothing happened so I don't understand why it is that after I closed the program and then relaunched it a day later, the menu interface was restored.
Anyway, I'll reference this when and should this occur again in the future.
Also, I want to say how much I appreciate your constant presence as a source of quick and very helpful answers!
Thanks so much 🙂
dk
