When I click the Layer Manager button in the main ribbon, nothing happens. The button itself highlights in light green, as if the layer manager is open, but I cannot find it. The same thing happens when I try to open it with "Tools," "Manage Layers..." I have dual monitors, but they are both hooked up and I am fairly certain that the window is not popping up off the screen. All of my other windows open regularly (materials, object properties, etc.).
Please help; I'm at the end of my wits!!!
And because you can run in the wrong direction with the cursor keys it's good to know that the dialog sticks to your mouse pointer after the first cursor keystroke, so after that, you can move it with the mouse.
And if all else fails, you can edit the 3dsmax.ini in C:\Users\_YOUR USERNAME_\AppData\Local\Autodesk\3dsMaxDesign\2014 - 64bit\ENU (Windows 7)
Look for this entry:
[LayerDialog]
Dimension=2239 0 400 871
The numbers are x-position y-position x-size y-size in pixels, reference point is top left.
