Were I work we have Max 2013 (with update 6) and noone here have seen this problem.
The top left Max-Icon - the one where you get the open, save, export, merge dialog, is sometimes freezes and can only be reactivated with a restart.
My workaround is that I've set a lot of shortcuts for open, save as, merge and export.
But what is going on?
Futhermore, I use OpenGL, but it also happens in Direct3D. Forget about Nitrous - I'm not using that.
It has happend on two different computers. One Windows 7 and one with 8.1. My graphic-driver is up to date.
Solved by Steve_Curley. Go to Solution.
Would do that in an instant, if I knew how to.... If I load 2009 UI it's stille there.
