3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to Scale in XZ When you are in Front Viewport
2 REPLIES 2
419 Views, 2 Replies
Hello, I've got this problem,
How can I Scale some vertecies in the plane perpendicular to the view (XZ, YZ, XY), for example in this image:
My usual workflow for this is:
1.- Select the vertecies
2.- Switch to "non uniform scale"
3.- change the view to a perpective or Orthographic viewport where I can see the axes needed
4.- Then Scale
What I want is to be able to scale without changing the view. Like this:
3.- Switch Axis constraint gizmo to ZX (because Im in front viewport)
4.- Scale
BUT when I do this, max doesn't Scale.
I've seen other post where ther suggest to change the coordinate system to "world" but max still doesn't do anything... Is there a way to do this?
any advice is welcome! thanks.
2 REPLIES 2
PROH
Hi. Here is what I would do:
1) Set the Coordinate system to "World". Now Z is up, X is to the right and Y is into the screen.
2) Select the vertices
3) Activate "Non Uniform Scale" and Right Click on it, so that the Scale Fly Out appears
4) Enter the Scale Values by number/spinner
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Thanks  For your answer...
Is there another way?, that method is more expensive than just change of view port... I would like to have a better way... perhaps it could be done with scripts?
