Area :: Header
Sweat, Swearing & Tears
Cupcakes & Critters reflects on what it takes to bring an indie game to market. Watch now
Discussion Groups
3ds Max / 3ds Max Design General
1 Kudo
Accepted Solution
How to get rid of black shades on mesh in 3ds max
3366 Views, 12 Replies
08-21-2013 12:06 AM
I am newbie to 3ds max, I was modelling one building but I am seeing some black shades on the mesh and I want to get rid of it. Please help me get rid of the error. You can see the black shades in the picture attached below, as well as I am uploading my 3ds max file.
Also guide me how can I get a cleaner mesh, right now its totally messed up. I used optimize modifier but it does not do much.
Moderator
515 Kudos
Re: How to get rid of black shades on mesh in 3ds max
08-21-2013 03:00 AM in reply to: tapandesai
You are correct in that it is "a mess". There are some rules which you need to follow if you want a nice, clean mesh though it will aways be at the expense of more polys. It's a subject which comes up regularly, so I suggest you read the folllowing thread carefully - there's a lot of info in it.
http://forums.autodesk.com/t5/Modeling/How-do-YOU-model-your-buildings/m-p/3963128
Max 4.2 through 2015 (SP3+EXT2), Composite 2014.
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 335.23).
1 Kudo
08-21-2013 03:16 AM in reply to: Steve_Curley
But at the moment I need some quick fix. I used Boolean to cut the windows and door and it messed up the topology.
What should I do to fix this quickly?
1 Kudo
08-21-2013 03:20 AM in reply to: Steve_Curley
I mean I am not worried about poly count, what I want is that I want to remove those odd black shades across the mesh.
Moderator
515 Kudos
08-21-2013 05:18 AM in reply to: tapandesai
There's no quick fix for a model like that. Right-click the object > Object Properties > Edges Only (turn it off). See all those long, thin hidden triangles? They are the cause of your bad shading. You have to get rid of those and the only real way is to either re-create the model (which will take a while) or to create new edges which should prevent those long thin ones from appearing (which could take as long or longer). It took a me a good half-hour just to re-create the front, and that's without those oddly shaped upper windows which complicate matters considerably, because of the extra edges/vertices describing the curved corners.
Distinguished Contributor
9 Kudos
08-21-2013 05:26 AM in reply to: tapandesai
You can try to use Smooth modifier, and let it try to autosmooth these faces.
If it doesn't help - ZIP the model, post here and I can take a look what can be done.
Moderator
515 Kudos
08-21-2013 05:29 AM in reply to: kcpr.pl
The scene is attached to the first post :smileywink:
9 Kudos
08-21-2013 05:35 AM in reply to: Steve_Curley
:smileywink:
Wow, thank you! I didn't noticed this.
I'll take look on this.
Greetings,
9 Kudos
08-21-2013 07:16 AM in reply to: tapandesai
Looks like it can be done :smileywink:
I've attached .max file.
what I did?
1. Applied Smooth modifier;
2. Then in Edit Poly I've selected front faces using By Angle: 45 - option, and then clicked Make Planar - Y axis.
3. You can experiment by disabling/enabling Prevent Indirect Smoothing in Smooth Modifier Options to achieve best results.
Please check if everytking is OK.
8 Kudos
08-22-2013 11:18 AM in reply to: tapandesai
A slightly shorter way, select object, enter Element sub-object mode, select face to highlight entire building, the click Clear All in the smoothing groups of the Polygon:smileyfrustrated:moothing Groups.  You do not need to set a smoothing angle or reassign smoothing groups necessarily because all of the faces are co-planar but you'd want to do this if you are dealing with curved surfaces to prevent faceting of the faces.  This is a common condition after using a boolean operation.
