Show only
Search instead for
I need to close a complex shape (see attached jpg). What would be the best and fastest way to do it? I tried "CAP", but probably because of the complexity of the shape, it doesn't work well.
Even if you were able to "Cap" this (& I don't think that's possible) you would still have to go & connect across the caped portion to give it its shape. What exactly is this object?
The object is a continent of Earth (Europe - In the attached jpg, you see the shape backward). I made all the continent that go around, and now I need to close all the shapes. I need to create a Earth globe,
If it's going against a globe, there's no need to cap it. If you are never going to see the back of it, leave it and save yourself the extra polygons you would have created.
