3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How Do you fix geometry errors
6 REPLIES 6
2276 Views, 6 Replies
I keep gettings this problem anytime I detach an object or create an object with a circle. I run STL check and guess what errors. This is the last thing I need right now. Could someone please save me? Smiley Frustrated
6 REPLIES 6
Steve_Curley
STLCheck is detecting "open edges" - edges which have a poly on one side but not the other. For an object to pass the STLCheck it has to be a continuous surface i.e. a solid object.
Your object is hollow - a single outer surface but no inner surface - try applying a Shell Modifier with a small Inner or Outer Amount as appropriate.
For that kind of object I would question why you're starting with a circle - try using a Line (Editable Spline) to describe the vertical Cross Section of the object (half of it) then apply a Lathe Modifier. Will still require a Shell to pass the STLCheck, but it's a much easier and more flexible way to create such objects.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
Thank you alot 🙂
You deserve a cookie
Steve_Curley
I like cookies 😄
If the solution answers your question you can click the Accept as Solution button and/or the Kudos button (the little thumb icon). Kudos are electronic cookies 😉
Max 2016 (SP1/EXT1)
Not to be confused with web browser cookies, or Girl Scout cookies. (Or my aunt Cookie)
Steve_Curley
Max 2016 (SP1/EXT1)
