3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
HELP - Need to convert a 2014 Max file to 2013 to work on.
4 REPLIES 4
15053 Views, 4 Replies
Is there any way to convert a 2014 Max file to 2013? Any online source that can do this?
Or, could anyone do it for me if you have version 2014?
I have 3DS Max 2014 at work and 3DS Max 2013 at home and need to work on a file that I forgot to save as a 2013 file.
Thanks!!!
4 REPLIES 4
RobH2
Go to the 'File' menu and do a 'Save as..'  Then, at the bottom where it shows the ' Save as type', click on the arrow to the right and it will drop down. You'll now see a list of legacy versions that you can save to.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Steve_Curley
in reply to: RobH2
Difficult if he's not at work. He knows how to do it, just forgot to do so 😉
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: RobH2
Max 2013 does have the ability to open a Max 2014 file
This was the situation I was in. I have version 2013 at home, and needed to open a version 2014 file.
Steve_Curley
Not strictly true though - 2013 cannot open a native 2014 file. The scene has to be saved (in 2014) as a 2013 compatible file before 2013 can load it, which not quite the same as being able to open a 2014 file directly.
At least we can now "save to a previous version" - prior to 2011 (IIRC) it was not possible at all.
Max 2016 (SP1/EXT1)
