Is there any way to convert a 2014 Max file to 2013? Any online source that can do this?
Or, could anyone do it for me if you have version 2014?
I have 3DS Max 2014 at work and 3DS Max 2013 at home and need to work on a file that I forgot to save as a 2013 file.
Thanks!!!
Solved by Steve_Curley. Go to Solution.
Go to the 'File' menu and do a 'Save as..' Then, at the bottom where it shows the ' Save as type', click on the arrow to the right and it will drop down. You'll now see a list of legacy versions that you can save to.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Max 2013 does have the ability to open a Max 2014 file
This was the situation I was in. I have version 2013 at home, and needed to open a version 2014 file.
