I am having a problem with the Graphite Tools Ribbon in Max 2015 sp2. All of the tools seem to display in triplicate. Is there anyone else who is having this problem or know how to reset it? I have tried reloading defaults in Max, reseting the ribbon to default, and even copy the working UI Ribbon files from 2014 to 2015 and overwriting them. None of these things have worked. Because of the installation process at work, reinstalling Max is the last resort! :{
Thanks!
Solved by chemicalpete. Go to Solution.
Hello-
Seeing triplate is not fun... Try resetting the ENU folder. Here's how: Reset 3ds Max
I look forward to your results.
Hello. Have you had a chance to try resetting the ENU folder?
I am going to close the case that was opened in tech support for this forum string and continue helping you via the forum.
I am looking forward to hearing back from you.
Best Regards.
