Solved by zainabalkenani16. Go to Solution.
Solved by Wake88. Go to Solution.
DarrenP
I downloaded 3ds Max 2013 and was having same problem. I switched the graphics to Software and it fixed the problem. Go to Start>All programs>Autodesk>Autodesk 3ds Max>Change Graphics Mode. Let 3ds Max start and change the graphics setting to "Software." I have an older computer with XP and a 128 MB graphics card and this worked for me.
Thank You Very Much Sir
i Did
And I got Suceess 🙂
@Wake88 wrote:I downloaded 3ds Max 2013 and was having same problem. I switched the graphics to Software and it fixed the problem. Go to Start>All programs>Autodesk>Autodesk 3ds Max>Change Graphics Mode. Let 3ds Max start and change the graphics setting to "Software." I have an older computer with XP and a 128 MB graphics card and this worked for me.
i have same problem, cannot used mode nitrous directx3d 9, and then i was tried to completely the directx3d 9. *perhaps my OS windows 7 doesn't have it
its worked... solved for me...
